Can anybody help ?! I can't play the game can anyone explain this to me ? I got a programe Starforce Nightmare in the CD I disabled the drive but it still doesn't work . Help , help , help !!!
Problem with playing Prince of Persia 3
You need an image with good dpm. Unplug your ide-drives, mount the image with DTv4 play.
Do you mean optical IDE drives? Yes you have to open the chassi.Originally Posted by RascarI don't know a lot about computers, so can anyone tell me EXACTLY how to unplug my ADI drives? Do I have to open my computer to do that?
Just unplug one of the cables at the back of the cd/dvd drive.
i'm always playing SF games with both cables unplugged.
is it okay if i let the power cable of the IDE plugged in and only plug off the IDE cable???
do i need to use DT 4 or issat also ok tu use 3.4
i thank u already, cause i still have deamon tools 3.47 installed, cause that is not asking when i am installing if i use kernel debugger, cause i have no idee. So please could someone help. I do not wish to instal DT4 cause it asks if u use a KERNEL DEBUGGER, so since i have no idee, i keep using 3.47 but issat ok to play PoP the two thrones? it does not work for me!
