plz read...
hi,
piratedkhan i all this stuff
and i got this error : cd key is not for the corresponding disk in the drive.
i SP2 installed and i was wondering if there is anyway i could make this work without putting sp1 or older sp2 .
hi,
Originally Posted by piratedkhan
dear friends: Salam and hi
let me solve u r problem
to intall price of persia the two throne just do the following...
system requirements:
windows xp service pack1 or the early release of service pack 2 in 2005 from microsoft.
demon tools 4.
1. mount the disk with daemon tools. and turn all on from emulation.
2. start menu and click run. in run window type k:\amir.exe /drv:install (where k:\ is u r daemon tools virtual dvd rome. k: is in mine case check u r own.) after that u will see dailog box saying " u want to install cd protection softwere. click yes ater that u will see another dialog box saying do u want to restart click yes and u r system reboot.
3. when u r system rebooting turn it off. open u r computer chasis and remove the power and data cable from dvd rom.
4. start computer. right clik on my computer : go to hardware tab and click device manger: in the ide controllers disable all which can be disable.
5. now install the game when installation of game is finishing in the wizard the last step. check the check box launch the prince of persia and click finish.
6. enter the key and enjoy the game.........
please comment
if problem presist i will reply
note: i was facing the same problem of the cd key is not for the corresponding disk in the drive.
but now working in service pack1. and be sure do all steps above..... enjoy
demon tools 4.
please comment
so the try creating the best image you can if you have the same problem as I had
how? ->
