What's New:
Version 1.3.0 (Pro):
CureROM has been completly redesigned from the ground up, with an improved/smoother user interface.
*NOTE: Because of new enhancements, all CureROM 1.1.x and 1.2.x profiles should be updated, this is not a
requirement just a recommendation (Profiles are backward compatable).
CureROM Pro boasts some of the most advanced Anti-Blacklist measures, to combat detection of
Virtual(SCSI) CD/DVD-ROM's By SecuROM and SafeDisc (NO more Registry key tricks).
Advanced Anti-Blacklist measures hides "Alcohol 120% (Tested v1.9.5.3105)" and "DAEMON-Tools V3.47" from
detection (Applications where tested using "FULL" & "MAXI" images, tests did not work using "MINI" images"),
also stops Blacklisting of some Third-Party Software.
New Feature(s):
+CureROM Lite:
- CureROM Lite is a new feature in CureROM which allows you to simply run CureROM with its Anti-Blacklist
measures without having to create a profile.
- Simply run CureROM.exe with the parameters "-lite" to activate "CureROM Lite", click "Enable" to start
Anti-Blacklist measures.
- Alternately run CureROM.exe with the parameters "-lite -autoenable" to start "CureROM Lite" with
Anti-Blacklist measures automatically enabled.
+CureROM Profile Shell Integration(Optional):
- Simply Double(Single) click a CureROM Profile(*.crp) to launch it.
- Right click on a CureROM Profile(*.crp), select "Edit CureROM Profile" to edit the profile.
+CureROM Commandline Switches:
*Info: Switches do not have to be in any particular order, CureROM will automatically configure the switches.
- "-launch [Filename]", launches/runs a CureROM Profile (eg: '...\CureROM.exe -launch "C:\MyCureROMProfile.crp"').
- "-edit [Filename]", edit a CureROM Profile (eg: '...\CureROM.exe -edit "C:\MyCureROMProfile.crp"').
- "-regfiletypes", Associate CureROM Profiles(*.crp) to open with CureROM.
- "-remfiletypes", Removes CureROM Profile(*.crp) file associations.
- "-lite", runs CureROM in "Lite" mode.
- "-autoenable", ONLY used with the switch "-lite", runs "CureROM Lite" with Anti-Blacklist measures enabled.
(eg: '...\CureROM.exe -lite -autoenable').
- "-runapp [Filename]", ONLY used with the switches "-autoenable", runs your application after applying
Anti-Blacklist measures (eg: '...\CureROM.exe -lite -autoenable -runapp "C:\MyApplication.exe"').
- "-hide", ONLY used with the switch "-runapp", hides the "CureROM Lite" dialog while running your application
(eg: '...\CureROM.exe -lite -autoenable -runapp -hide "C:\MyApplication.exe"').
- "-exit", exits/closes CureROM after running a switch (eg: '...\CureROM.exe -regfiletypes -exit'
-OR-
'...\CureROM.exe -lite -autoenable -runapp -exit "C:\MyApplication.exe"'
-OR-
'...\CureROM.exe -lite -autoenable -runapp -hide -exit "C:\MyApplication.exe"').
Additional Features:
+Welcome Page:
- Added Browse functionality to "Open Existing CureROM Profile".
+Application Page:
- Replaced "Hide SCSI CD-ROM Devices" with "CureROM Anti-Blacklist Measures"
- Removed "Smart SCSI Hider", this function is no longer required.
+Virtual Drive Page:
- Virtual Drive Device Selection.
- Suspend CD/DVD-ROM Autorun.
- DAEMON-Tools Emulation Options.
+Shortcut Settings:
- You don't have to create/re-create shortcut(s) when creating/editing a profile.
+Save Profile (*New):
- Option to save a profile at a user defined location.
+Settings:
*Info: "VCD" refers to "Virtual CD/DVD-ROM".
*Info: You will need to re-configure the standard VCD's (DAEMON-Tools/Alcohol) with the new version of CureROM.
-Improved features for third-party VCD's, you can now use CureROM with "DAEMON-Tools", "Alcohol 120%",
"Alcohol 52%" and a custom VCD application of your choice (As long as it supports command line parameters).
+Notes:
+Using a custom VCD application:
+Mount Arguments:
-These are the arguments that will be passed to the "CUSTOM" VCD application to "mount" an image on a
virtual drive, if using a standard VCD application(eg: DAEMON-Tools/Alcohol) the arguments will be used
in conjunction with CureROM's arguments to "mount" the backup image.
+UnMount Arguments:
-These are the arguments that will be passed to the "CUSTOM" VCD application to "un-mount" a virtual drive,
UnMount Arguments are not supported for standard VCD applications.
+Variables:
- %IMAGEFILE% = This is the CureROM variable for the path to the image file (it is not recommended to use this
variable when using a standard VCD Application).
View the readme.txt for some examples on using "Custom VCD's"
Download Locations (CureROM 1.3.1):
RapidShare
MegaUpload
GameCopyWorld
GameGuru Mania
New Feature(s):
+CureROM Lite:
-OR-
-OR-
+Welcome Page:
+Application Page:
+Shortcut Settings:
+Settings:
+Notes:
+Mount Arguments:
+UnMount Arguments:
+Variables:
RapidShare
MegaUpload
GameCopyWorld
GameGuru Mania
but i think theres a serious problem somewhere in the proggie. this is what happened:
