Originally Posted by sYk0
CureROM Pro 1.3 (Released)
^Btw guys ...the Stars Wars problem thread is over at
http://www.daemon-tools.cc/dtcc/t982...r-save-me.html
That is definet. no CureRom Problem so its offtopic here
Well if you dont believe me
Heres mine:
click for image
Edit by Underheaven: I replaced the image with a link so the forum layout doesn't get busted anymore.Guys vote for the threads you read to give
Well the problem I've been describing is from the cure thing. Its not a star wars problem. Star wars runs just fine, its cure that freezes up my win XP pro (if I have a windows explorer window open after the game exits and it tries to disable the protection, or I tell it to disable the protection).
Oh i had that one too but it seems rather erratic and doesntOriginally Posted by DarthTyranusWell the problem I've been describing is from the cure thing. Its not a star wars problem. Star wars runs just fine, its cure that freezes up my win XP pro (if I have a windows explorer window open after the game exits and it tries to disable the protection, or I tell it to disable the protection).
happen every time.
U can close explorer.exe with taskmanager , and then in the
taskmanager go to "FILE" -->New Task (i think in english thats
how it is) and start explorer.exe again. At least for me that
was a workaround.Guys vote for the threads you read to give
Why u think its only me? Please attach your version ofOriginally Posted by sYk0Well, does anyone else who uses Kaspersky, have this problem?
madchook.dll here in the thread and i will get it and
scan it. Maybe something is goofy on my rig
And you sure that on your kaspersky the dll file is not on
the exclusion list already
? The weird thing is you can
still scan it then but it wont pop a report even if its the
only file you scan
BTW I USE THE EXTENDED DATABASE TO SCAN...not the default setting
Last edited by Sabrehawk; 21.02.2006, 15:57.Guys vote for the threads you read to give
sYk0, I'm having persistent problems with Curerom. Every time I try to use antiblacklist measures I get the same response
I have used Dependency walker and found an error, lookError starting CureROM Anti-Blacklist measures
click for image
Delay-load module warning. This module is either missing one or more export functions that are required by its parent module, or is of the wrong CPU type. For a missing export, the Parent Import Function List View will list the actual unresolved functions that are missing. For delay-load dependencies, this is most likely not an error since one reason developers use delay-load modules is when they are unsure if a particular function exists in dependent module. Parents of delay-load modules have techniques for recovering from missing exports in the delay-loaded dependent module.
I have no clue what could be the problem. Please help.
Edit by Underheaven: I re-linked the image so the forum layout doesn't get busted anymore.
