Ok. I have Myst 5. I know it has SecuROM, 7 protection.
I am a little fuzzy on how I make a backup... or if I can?
I am not sure what to do with Daemon Tools. It emulates the copy protection scheme, but how can I make a working backup? Do I make a virtual cd drive, burn an image using BlindWrite, mount it on the virtual cd drive and install it from that virtual drive with the SecuROM 7 emulation turned on?
Is it possible to simply copy the disc using some other software? I tried BlindWrite outright, but the disc doesn't work. Can I run it from the disc copy and point Daemon Tools to the cd drive?
Thanks
Nivlac
Thanks
Nivlac
