hello. m having trouble installing the OFB exp pack.
i already installed sims 2 by doing the following:
installing the game using the four cds
mounting an image on Alcohol 120%
playing for hours. (just to make sure it works)
anyway, now i can't install the expansion pack. i thought i'd go by the usual route and install the game first before mounting an MDS on alcohol, but i can't complete it because once it gets to 100%, it says that it has to make sure my sims 2 game is updated so it asks me to insert disc 4. once i do, though, the installation uninstalls and it says that it's unable to copy from the cd.
i tried another route: mounting an image first on alcohol, then installing the game. again, same problem.
can anyone help me with this? please? i don't get how i can play the game after only mounting an image on alcohol because, er, i don't see the OFB icon on my desktop.
or is it really okay to just mount the image without manually installing the game? if so, how does one do that?
thank you very much!
