For me doesn't work either Pro Stop, either SecuROM_Loader_v7.26... any idea to make it work?
Caesar Iv - Securom
I am using Daemon 4.03.
I've tried ProtStop + Disabling all other drivers + Procyon + SecuRom Loader 1.2 .. Nothing seems to work for me
I keep getting:
A required security module can not be activated.
This program can not be executed (12004).
Any other options?
I just deleted a dozen duplicate posts. This is unacceptable.
The forums are moderated, and everyone who posted more than once in this thread, consider yourselves warned. Next time you double post a message, you will be banned immediately. Keep your patience, your posts will be approved, as long as you're not talking about anything illegal."I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
- i also have the same problem... it only works for once when i use SecuRom to load the caesariv.exe.. but when this "Microsoft blah blah runtime error" showed up.. i cannot use the SecuRom to load the caesariv.exe anymore.. so i what i did next is to send the securom to desktop and did the "e:\.....\asr.exe" -r caesariv.exe ....... still wont work.. the error msg still comes out...(Microsoft .... runtime error)Originally Posted by RosinantWell, SecuROM loader 1_2 works for me though. The problem is that Caesar IV then reports Invalid save game... (what save game?!) on splash screen when loading first campaign. If I try to restart the game I get this message Microsoft Visual C++ Runtime Error. (All drivers are updated, SP2 installed, so is .NET 2.0, MSQL, April's DirectX 9.0c) The game itself is big bunch of bugs and no one seems to find out why.
can anyone tell exactly what to do.. it will be better if its step by step...thnx.. hoping some1 cud really help
Works
Few steps:
1.Must have image of cd1+2(ccd-cr4a MDS file and ccd-cr4b bin file) only.
2.Latest daemon tools 4.06he
3.Prot.stop v1.0
4.Games REQUIREMENTS
Now hacking:
Install game full with daemon t.,copy the <prot.stop>in the path directory of game,mount cd1 again,runprot.stop(hide),play game from main menu(mounted with daemon t.)
So works for me...play by Winy
