Hi, I have been reading through the posts here, but i can't seem to find any posts with my problem. The strange thing is that i'm not the only one with that problem. Some of my real life friends have the same problem, so now I/we hope that you guys can explain what it is. Here is the problem.
For a long time i've been using DT 3.47, I think that DT is the best virtual drive software ever made, so thanks a lot for that
I have many image files, most of them are CloneCD rips and works fine with DT 3.47 Now i installed the new DT 4.06 and after i reboot, the stranges thing happen. When i want to mount an image, i can see that the image is mounted in DT, but when i go to My computer I can't see it there, and i can't right click the virtual drive. Also, it doesn't start up the image at all, eventhough i have check autostart in the options.
As i said a few of my real life friends have the same problem. So any idea what to do?
Hope you guys can help me, cuz i would really like to use the new DT =)
I have many image files, most of them are CloneCD rips and works fine with DT 3.47 Now i installed the new DT 4.06 and after i reboot, the stranges thing happen. When i want to mount an image, i can see that the image is mounted in DT, but when i go to My computer I can't see it there, and i can't right click the virtual drive. Also, it doesn't start up the image at all, eventhough i have check autostart in the options.As i said a few of my real life friends have the same problem. So any idea what to do?
