I have several bin files that were riped from dvds.
they are in the svcd formats.
I am using the directdvd player to play the mounted bin image files.
when i goto play the emulated dvd drive, the player returns the following error message: "DVD disk not found..please insert a dvd".
btw, i do not have problems playing the svcd bin file with windows media player or divx.
is directdvd not recognizing the mounted image because its in svcd format?
or is it a stealth dvd drive emulation problem that is incompatiable with the player?
for those who use this player, what types of dvd ripped files are compatible with it?
thank you so much for your help.
