Im on Window's XP, and i downloaded lite, then used winrar to extract it, then it because the computer-looking-icon. then i double click to install and it says
"This OS Version is not supported. Supported OS versoions: Windows 2000 SP4, Windows XPx86/x64 SP2, Windows 2003 x86/83, Windows Vist x86/64"
Also, on daemon tools i cant seem to mount .exe or iso (lol not sure which one i just know its one of them, and .mpq(the one thats more important, if it doesnt work on mpq, how do i change it?) I mount it, then i double click on the cd, and i get this error that says
"Windows cannot read from this disk. The disk might be corrupted, or it could be using a format that is not compatible with Windows."
Okay, as you can probably tell, i know nothing about computers.. this much is true. so explain clearly
Please and Thanks!
Please and Thanks!
