Im trying to mount an image and "Unable to mount image. File not accessable" shows up. I tried DT pro but that doesnt work either. Any solutions?thx
Unable to mount image.File not accessable?
How you created the image?
Does it contains special characters?
Does the mds and mdf file has the same name?
If not mds/mdf image, which format?
Your Windows and Daemon Tools version?
Where is the image stored (e. g. network drive, internal ide/sata hdd, external hdd...)?Make something idiot proof, but then they just make a better idiot
You may need to edit the .cue file..
Hello, I was having the same issue as you, and I found out that I needed to edit the .cue file. When I received the image, I changed the name to a more descriptively name, what I didn't know is that inside the .cue file (Which contains the reference to the image, in this case .bin), It was set to the previous name that the .bin file had. So here are the steps:
After renaming the .bin file, open the .cue file inside notepad (Or text editor), and on the first line (FILE "filename.bin" BINARY), Change it to the appropriate name of the .bin file. Save it, and try to mount it again.
I hope this solves your problem.
