On previous page I explained how circumvent blacklist.
Arma 2 Emulator detected+Yasu 1.6.9040+Deamon Tools Lite 4.30.4.0027
I have a similar config (AMD RS780C+SB700) and for me it works in Vista x86Originally Posted by jznomoney View Poststill does not work for me. I have a am2+ mb with an amd chipset with the sb700 northbridge.
Which error message do you get ?
How do you know ?Originally Posted by jznomoney View Post... because it doesnt seem to work with the mds file i have.
LOL this is just the standard way.Originally Posted by Chuck Norris View PostI sorted out the problem - what i did is, install Daemon Tools Advanced Pro, then put Yasu 1.6.9040 in the Daemon Tolls folder, run it and click cloak.
Then mount the image and install the game. After it is installed just run it and it should work. Worked for me
I have a gigabyte GA-MA78GM-US2H rev 1. It is a 780g mb with a sb700. I have raid enabled and my DVD Drive is SATA loaded as scsi because of raid being enabled. I also tried it with disconnecting my dvd drive from my pc and it still failed. I tried using daemon tools lite, alcohol, and dt pro with yasu with the end task method and it still fails to launch.
That works IF your OS is Vista or Win7 but NOT XP!!!Originally Posted by Chuck Norris View PostI sorted out the problem - what i did is, install Daemon Tools Advanced Pro, then put Yasu 1.6.9040 in the Daemon Tolls folder, run it and click cloak.
i uploaded it here.. with this fixed mds file, you CAN mount it in xp + update game to 1.02Originally Posted by lasershock View PostI'll gladly take it, because no matter how I rip my disc the mds file is still "unrecognised file format".
Send big files the easy way. Files too large for email attachments? No problem!
So does it work with patch 1.02? and what do you do then when you reboot?Originally Posted by Chuck Norris View PostNo, you see right, if you mount it before cloaking with YASU and install like that, it doesnt work, well atleast on mine it didnt.
Thats on Vista 64 SP2
1: Run yasu
2: mount image
3: start game
?? is that how you did it?
