Yep, thats what i did. Then to patch it, on some working keys it might say Wrond CD Key when patching it, on mine didn't. To patch it, Yasu /cloak it, mount image, run patch.
Then it came out with a message "insert original disk instead of backup"
You uncloak, exit Yasu, unmount image, exit DT Pro - DT will still sit in task bar, you need to exit from there aswell. Then normal procedure again, Run DT, Yasu / Cloak, mount image, play.
I hope it works for you
