(I use Vista)
Ok so I obtained the Rosetta Stone program for German from, and I'm having a little trouble figuring out how to get it to work. Each disk came in a .zip file. I looked through it and didn't see any .iso file to mount it on Daemon Tools, so I just mounted the .zip file and went to My Computer to start the program, and when I right clicked and chose to install it, it wouldn't play. It said something about not being able to play and just said "F:/" but thats it.
Now every time I try to mount the image and right click it on My Computer, it just gives me the option to Explore it rather than Install it. When I Explore it, it just shows the files that are in the folder, nothing else. Inside the files (which are titled by lessons) are MPEGs.
It's mounted on virtual drive (F: ), and I'm on a laptop. I haven't had any problems playing any other mounted programs, like Rollercoaster Tycoon or Warcraft III but those were .iso files and this one didn't come with one. Does anyone know a possible solution?
