Operating System: Intel pentium 4
Burning Software: ehm roxio easy cd burning software
Anti-virus Software: Norton anti virus protect
DAEMON Tools Version: 3.47
Ok i dowloaded Medal of honor Pacific assault Directors cut ( the dvd cd one with special features )
I mount the image and it loads the little menu and i install ... everything goes well i insert Cd key and it finishes installing ... i go to school and get back and check the special features
Ok now its time to play , so i click the shortcut and it loads the little menu i select Play it brings up the Settings , i click play again and The game thing loads but i get an error message that sayS " Please insert Correct DVD-ROM, select ok and restart application " so im like wtF? i tried it again 3 times still same thing , so i go to the help section in DT and found a question in the FAQ that sounded like my problem
i got a raw 1-1 image , it installed but the game dont work
it told me to go and change the drive letter ... ( i tried E to H and no luck so i gave up and decided to come here )
Can anyone help
im using DT version 3.47
*EDIT*
update i was looking through the Read me with the Rar dowload and in the read me the fift step was this
5. Copy over the cracked executable from the /Crack dir on the DVD to your
install dir.
I didnt do that ... maybe thats the problem ... but i dont understand what it wants me to do
Can anyone help
*EDIT*
install dir.
