I have a brian lara DVD image file, i tried installing the game using sfcure and sfnightmare but i didnt follow steps properly. The steps in SFcure are:
1. Mount the image on daemon tools
2. Run !setup.bat, reboot and install the game
3. Run SFdrup.exe and reboot
4.Disable all CD/DVD drives using SFnightmare
5 Run !start.bat and start the game enter the serial key wen prompted
BUT I FOLLOWED THE FOLL STEPS:
1.Mounted on daemon tools
2. Ran !setup.bat rebooted and installed the game and started the game and entered the serial key
THE PROBLEM IS THAT IM NOT ABLE TO RUN THE GAME
it says ENTER THE CD IN OTHER DRIVE
now i want to reinstall the game but if ill reinstall it dosent ask me for SERIAL KEY????AND the same prob it says to enter in other drive
Can anyone help me out so that i can install the game and enter the serial key again,and i can follow proper steps and i can play the game properly
