So I have the image file mounted on Daemon for Fm2006, it worked for 3 months, then one day it just stops, I click on the shortcut, the hourglass appears, but nothing happens, nothing goes into the processes in Task Manager.
So, I download it again after uninstalling, mount the image, it doesn't autorun, so I have to go into My Computer and run it from there. It installs fine, then I click on the shortcut again, it works!
Now, coming back to it the day after the same thing happens again, I uninstall/reinstall and it does nothing.
Any body get the same problem?
Should I be running say Anti Blaxx as well.
I have XP.
Cheers & hello there!
I have XP.
