Hey,
I could use some help, regarding how to play downloaded .mdf games.
Basically, I mounted the .cue with DAEMON tools, and then used a patch to play the game. The first time I did, everything was fine - It worked perfectly.
However, since then, I have tried to get the game working, but it just wont have it at all. Ive deleted no files, changed nothing at all, but when I double click, no game will load up.
I downloaded another game aswell (Which I put onto disc), and had the same problem. The first time I tried to play it, perfect. The next time I loaded up the PSX emulator, nothing happened at all.
Any help is hugely appreciated here
Thanks a lot
Jack
Thanks a lot
Jack
