Oh no,
its possible to create an 1:1 Copy of StarForce 3 protectet CD's.
But its very hard.
I try to discribe how it will function.
What you need:
Blinwrite and the BWA (Best is BW Version 5)
So next to do is read the CD wich is protected and Save it as Image.
Than extract the BWA form the CD. (save it in another directory than the image)
Next to do is to burn image on a CD-R with lowest speed and without any RMPS or BWA infos!!!!
Now you have to extract the BWA from the new burned CD again.
And save it in another directory as the first original. Ok?
So, now it cames the really hard job.
You have a code wich you enter at Install the CD,
wich indentifies that the CD is original.
(StarForce is AngleBased Copy Protection, the Code there to get the Messuring Points)
Look at the original BWA and the BWA from the Copied CD-R.
You have to create a new code for the Copied CD-R.
Use HexEditor, but i tell you, its not easye to make new Code.
(looking in EXE/DLL for infos how it will check code)
If you have generated a new Code wich is function after Install the copied CD , than you have a 1:1 or better sayed a new Original Protected CD.
But its very hard.
What you need:
