That's right, you need to uninstall StarForce with the official StarForce driver removal tool if you want to create DPM images with Alcohol 120%. Alternatively you could try Blindwrite which is not affected by StarForce.
Splinter Cell: Chaos Theory problem
Your welcome!
I actually had some problems getting the game to run today, but then I found out that you have to press disable node and disable cd, and then launch SC:CT IMMEDATLY afterwards! If you wait, or restart computer you have to run SFnightmare again, even if no cdroms are displayed in my computer! Then it works every time!
I have a question will using the disable cd/disable node options f**k up my computer if I do them while I have the nforce 2 IDE universal controler or will it only f**k up when you also use the Primary/Secondary master/slave ch off options? because I realy don't want to uninstall my ide controler so I can remain on the ms standar onesThe last of the best, the death of the rest. Hitman Forever...
With SFnightmare you don't uninstall anything. Just press disable node, then disable cd, and your off playing. When you want your cdroms back, just click enable cd and enable node, then you have them. No need to restart! I don't think it will f**k up your computer. I never heard of anyone having problems if you ONLY use these two functions in SFnightmare.
If you cannot download it from the primary site, here is a link to the file on my server.
http://home.no/cursio/sfn/Splinter_C...pybase.ch].mds
