i dont need to run protstop to play the game. i'm just using cureROM...
Titan Quest
How did you create your image (read settings used)? Did you use the latest CureROM?
@ DaS_ScHaF,
Download CureROM 2.0.3.1 from hxxp://www.curerom.net,
once installed run the short from "Start Menu\CureROM\CureROM RegKey Removal", then proceed to make a CureROM profile for the game.
"CureROM RegKey Removal", removes some registry keys from you system wich may cause some SecuROM game to fail to start.Mail:
curerom @ daemon-tools.cc
CureROM is indeed one of the best tools i've ever seen!
great respect goes to sYk0!!!
Originally Posted by LooDosCureROM is indeed one of the best tools i've ever seen!
So follow this steps and u can use the mini image with out problem
Go to start, run, write regedit
Then find HKEY_LOCAL_MACHINE , software, iron lore, titan quest
In titan quest you will find CD KEY reg_sz XXXX.. (your key) copy this key
Now go to the other folder 1.00.0000 and you will find (Default) REG_SZ
Double click in default and paste the cd key used in the folder before
Save it and ENJOY
Xiphias
Its pleasure to return a favor
I must be doing something wrong. It won't work for me. Asl 1.2 crashes when I load the .exe
I have the newest version of Asl and DT (4.03HE, SPTD 1.25)
I also tried to unplug my optical IDE drive and start without asl but still I get an error that the game found active emulation software
Any tips, what I might try?
