Can anybody show me in detail how to work on the Worms 4 SF?
Worms 4 Mayhem
You can also disable your optical IDE drives with software tools
benitojuarez has explained the best method for running new tiles.
You can also disable your optical IDE drives with software tools. See this post for recommendations on what to click when using Starforce Nightmare.the modern world:
I found it better to:
Turn off PC
Unplug CD\DVD-ROM IDE cables
Turn on PC
Run game
Unplugging the power only and my PC won't boot. (Perhaps it can detect that the IDE cables are connected to something and freezes trying to detect them.Goodnight Brave Warrior, Goodnight Monster-land..
OK, DT4 is out, so images work now. But, I still burn backups. They are backups. An image isn't a backup. My discs always come in pairs: 1 pressed, 1 backup. I even make backups of my hard-disks. I have 4 HDs. 2 installed and two in the closet containing the data of my installed ones.To contact me privately, pray. I might answer.
umm im not so sure about that one, worms 4 image does not work, I even unplugged my IDE drives and no use. Someone?Originally Posted by NikosOK, DT4 is out, so images work now. But, I still burn backups. They are backups. An image isn't a backup. My discs always come in pairs: 1 pressed, 1 backup. I even make backups of my hard-disks. I have 4 HDs. 2 installed and two in the closet containing the data of my installed ones.
The image must contain good DPM data, or it won't work. Alcohol sometimes doesn't do a good enough DPM extraction with some drives.
To be sure, you can create an image with Alcohol without DPM extraction, and download a file containing a good DPM (*.bwa or *.mds).To contact me privately, pray. I might answer.
Yes. They said that there will be an update to the free version soon that will not require you to disconnect IDE drives.Originally Posted by [UFP]Ghostbusteri'm not good with technical stuff and everything, but the jist is that dt4 can't get it toworkwithout unplugging it, and they are working on it? didn't really understand the front page.To contact me privately, pray. I might answer.
There is another way around disconnecting your CD drive, this is what i have done.
I have installed a switch on the power cable to my pc that sits outside the machine, when i need to disable the cd drive I flick the switch which cuts the power from the drive. I then go into device manger and scan for changes and the DVD drive vanishes. You can then mount a good image of Worms into the DT4 virtual drive and play the game.
Works for me
OK, can you help me out with this?Originally Posted by NikosThe image must contain good DPM data, or it won't work. Alcohol sometimes doesn't do a good enough DPM extraction with some drives.
I need a step-by-step on how to burn with alchohol 120% that file format, is there something I should do and if I should disable the RPSM or something.
